Webcast-Catalyst9k
TCC3 sw
Hello
I am looking for all possible SW versions for a TCC3 card. Do you have to upgrade the IOS or just the module?
Everyone's tags (1)
TCC3 sw
ffyyocum,
You can put either MSPP or MSTP software on the TCC3 card depending on your application. The latest is 9.4.0.1 is out for MSTP and 9.2.1.3 is out for MSPP. I believe after 9.2 for the MSTP you need to download the lite versions if you have a TCC3. It will state this on the software download page. You can find the download software page at the link below. You'll need a valid Cisco username/password and software license to download which will be stated on the download page.
http://www.cisco.com/cisco/software/navigator.html?mdfid=268437886&flowid=304
Hope this can get you started in the right direction.
Ryan
Re: TCC3 sw
Thank you
434
