Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Temperature via TL1
Hallo.
How can i get temperature of the node 15454 via TL1? I want to put this value to database.
I was used utility getTemp.exe (WIN) for this before.
getTemp.exe (Cisco ONS 15xxx NE Temperature Monitoring Utility 1.0.)
Re: Temperature via TL1
There is not a TL1 command for retrieving the temperature of the node. It is only visible on the shelf's fan tray assembly.
Thats not true. You can scan it via snmp.
235
