Two different SFP tranceiver on the same switches
I have 2960 and 3560 switch. The first link between them is using GLC-LH-SM. I want to have second link using GLC-BX-U. Is it possible to use two different SFP transceiver like that? I think it shouldn't be a problem, but need expert's advice.
Thank you.
B
Re: Two different SFP tranceiver on the same switches
B
You can mix different SFPs in the same chassis; just like you can run different port speeds on a switch.
You cannot run these particular SFPs links over the same fibers. You will need a different fiber for the new link.
One note: The single fiber application needs the GLC-BX-U and GLC-BX-D SFPs.
Hall of Fame Super Gold
Here's a page that might be helpful to you in the future.
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix (http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html)
yes, its possible to have two different SFP type on a switch. please check Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix in attached file.
603
