Community Member
UPSR ONS15454
Does anybody know if there is a maximum number of nodes you can have on a UPSR. Or maybe is there any limitation on the number CTC will support?
I have 6 UPSR's. 3 OC-12 Rings and 3 OC-48 Rings with a total of 29 nodes. My biggest ring is an OC-48 Ring with 9 nodes and I will probably add 2 more nodes to that UPSR here in the near future and was just wondering if there were any limitations? Of course, I already know there is an STS limitation on the OC-48 ring, it was just the number of nodes I am concerned about.
Any help would be greatly appreciated!
Community Member
Re: UPSR ONS15454
Here is some of the info you are looking for:
This is number of rings (Path protected)
path protection with SDCC 34
path protection with LDCC 14
path protection with LDCC and SDCC 26
This is just part of the information. Read all of the section on path protected rings (ie UPSR).
Here is a link for ring information:
http://www.cisco.com/univercd/cc/td/doc/product/ong/15400/r72docs/r72rf454/r72topl.htm#wp116456
Hope this helps,
Tim
Community Member
Re: UPSR ONS15454
The official stance of Cisco is that your network can contain 50 nodes or less per CTC session.
Kindly refer to the following link:
http://www.cisco.com/en/US/customer/products/hw/optical/ps2001/products_tech_note09186a008061ca28.shtml
426
