Community Member
VxWorks login?
If I telnet to a 15454, what is the default VxWorks login? There are times when we are turning up systems that we cannot reach them remotely with CTC/CTM, but can reach them via Telnet. I have tried 3 different logins that we have had our field engineers build into them and none are working, so I assume they are different from the "normal" logins for the shelf.
Silver
Re: VxWorks login?
In version 3.3 and later, the username and password are the same as the CTC username and password. To see the number of ONS 15454 TL-1 sessions using VxWorks commands.
http://www.cisco.com/warp/customer/127/ONS_15454/454_8100.html
Community Member
Re: VxWorks login?
Almost all of our NEs are 2.2.0. Any idea on that?
3421
