Community Member
What series of Cisco Switch I Need?
Hello colleagues,
I want to know which Industrial Series Switch I need to choose and meets the following minimum specifications.
-at least 4 SFP ports 1Gigabit
-at least 4 PoE port 100MB
-IP20 or IP30
I can use extra modules for to achieve the minimum technical specifications.
I appreciate your time and hope you can help me.
1 REPLY
Hall of Fame Super Silver
The IE 3010 only has two SFP ports. To get 4 SFP ports and the PoE copper ports you're asking about you would need the IE3000-4TC with one expansion module for PoE ports (IEM3000-4PC) and another for the additional fiber (IEM-3000-8FM). you would also need to add the separate power module for the PoE.
Reference the product data sheet. they ar rated for IP20 or 21 per the hardware installation guide technical specifications.
846
