Which module can adding for catalyst 4006
My network will upgrade backbone use 100 base single mode fiber optic,at present we'd been used catalyst 4006,and catalyst 2950.Could you tell me which module I need to install for two catalysts.
(At present, two catalysts onlu use 10/100 (RJ 45) module.
Thank you very much.
1 REPLY
Gold
Re: Which module can adding for catalyst 4006
you will need a fiber to copper converter.THere are quite a few available on the web.
Unless of course you want to do a hardware upgrade.
174
