Which product is for replace the EOS 15454-OSCM
http://www.cisco.com/c/en/us/products/collateral/optical-networking/ons-15454-series-multiservice-provisioning-platforms/end_of_life_notice_c51-728080.html
The 15454-OSCM is end of sale.
But I haven't found any devices for replacement it.
Need help.
Thank you
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hi,Because 15454-OSCM and OSC
Because 15454-OSCM and OSC-CSM are eol\eos I recomed you use GCC channels on transponders. When you use OSCM or OSC-CSM you get GCC only bandwidth 192 kbps, but when you use cards like 10x10 or Any Rate cards you will get 1200 kbps.
To create GCC without OSC channel you need:
- DCN, I mean LAN connection between nodes
- Create Side-to-Side PPC
- Create channel 10G
- Create GCC. Then you can delete DCN network
Other way migrate from M12 to M6 and use TNC card with CWDM SFP (1510 nm) for OSC channel.
1 REPLY
162
