Community Member
Workaround ACL limitation WiSM
Hi all,
ACLS configured on WiSM got a limitation of 64 lines.If I have FWSM on the same chassis, are there anyway to offload the ACL function to FWSM ?This will enable more than 64 lines ACL.If thats not possible,what is the workaround?Cannot summarise any existing statements :(
thanks,
Janesha
HW/Software Specs
WCS ver5.0.56.2
2 6 Firewall Module WS-SVC-FWM-1
7 2 Supervisor Engine 720 (Active) WS-SUP720-3B
8 2 Supervisor Engine 720 (Hot) WS-SUP720-3B
10 10 WiSM WLAN Service Module WS-SVC-WISM-1-K9
11 10 WiSM WLAN Service Module WS-SVC-WISM-1-K9
Silver
Re: Workaround ACL limitation WiSM
you have posted in wrong section, post this in security section where you can get right people.
Community Member
Thanks for pointing that out.Did not realise that i was in the wrong forum.
I think I will try wireless forum first which I should have done in the first place!!!
259
