WS-C3750-24FS-S to media converter
javierfonseca
Hello.
I've recently started the "SFP to media converter" thread.
Now I'd also like to know if this variation would work:
WS-C3750-24FS-S at one end.  It's a 24 ports 100Base-FX (MT-RJ connector) switch.
AT-MC101XL-10 at the other end.
Over 62.5/125 multimode fiber.  Length wouldn't be longer than 700 meters.
Do you think it would work?
I've attached both the datasheet and installation guide of the media converter.
Thank you,
Javier F.
Tom Randstrom
Shouldn't be any problem.  Just make sure to order the correct optical jumper cable to match the MT-RJ switch port to the media converter port (ST or SC).
Tom Randstrom
Thank you for both answers !
Sincerely,
Javier F.
