WS-X6704-10GE -10GBASE-SR
Hi All,
We have a 10G DWDM circuit terminated on 7600-sup720-3bxl (WS-X6704-10GE,10GBASE-SR) interface and we get below optical receive power measured on the router
sh interfaces tenGigabitEthernet 9/2 transceiver (o/p modified for simplicity)
Optical
Rx Power
Port (dBm)
Te9/2 -2.6
We are trying to understand,what would be the cisco recommended optical rx power levels. Any help on this would be really appreciated.
Anantha Subramanian Natarajan
2 ACCEPTED SOLUTIONS
Re: WS-X6704-10GE -10GBASE-SR
Per the following data sheet, the XENPAK-10GB-SR module has a receiver range of -1.0 (max) to -9.9 (min). Your -2.6 dBm input would fall within the range.
What transmit equipment (specs) is connected to this receiver port? Might you have a optical power meter handy to verify the router's reading (I can dream)?
<http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps5455_Products_Data_Sheet.html>
Hall of Fame Super Gold
You want the Data Sheet for Cisco 10GBASE XENPAK Modules? Here's the link:
Does this help?
Have you checked the Cisco 10GBase DWDM XENPAK Modules Data Sheet?
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6576/product_data_sheet0900aecd801f9333.html
Hope this helps.
Hi leolaohoo,
Thanks for the reply. We using a non-colured XENPAK and no wavelength mapping upto the router. Do you have a link where there is a data sheet for normal xenpak terminating 10gig interface on 10Gbase-SR interface type.
Thanks once again
Does this help?
Hi Leolaohoo,
Yes and thank you very much
Thanks for the rating, Anantha Subramanian Natarajan.
No problem and thanks for the help
626
