7912 Phone - Block PC Port ?
Justin Brenton
Level 4
Level 4
Does anyone know if you can block the pc port on a 7912 series phone?
Rob Huffman
Hi Justin,
As you have seen, the "Disable PC Port" setting is not available on 7912's. The only way to disable the PC is via your Switchport Config (setup with only Voice VLAN and no Data VLAN).
Hope this helps! I know it's a pain :(
Rob
PS: Hope all is well in Banff!
Hey,
Thanks for the help, I figured that would be my only option.
All is well in Banff. How are thing's in Calgary?
Thanks Rob
Hi Justin,
All is well in the Cowtown! Busy but good :)
Take care,
Rob
