10-06-2003 03:51 AM - edited 03-13-2019 01:55 AM
I have encountered an issue when using Avaya's IP softphone with Cisco's IPSEC VPN client software. A remote Cisco vpn user can connect to the central Avaya IP Office server, but voice does not work. Avaya says that IP Voice works with site-to-site vpn but does not work with Cisco's remote VPN client.
Any suggestions, recommendations, or workarounds would be appreciated.
Dan
10-10-2003 06:46 AM
Disable the QoS Packet Scheduler for the VPN client adapter and this should work fine. ANd also use VPN client above 4.x
10-10-2003 07:25 AM
Thank you. I will give it a try and let you know how I make out.
Dan
10-14-2003 03:49 PM
Thank you. That resolved the problem.
