03-15-2006 11:22 AM - edited 03-13-2019 12:33 PM
Is it possible to have call routing based on the incoming caller ID instead of the dialed number in the following senecarios:
(1) Calls from PSTN to CallManager 3.3
(2) Calls from PSTN to CME system 3.1
JJ
03-15-2006 01:50 PM
if h323, just use a dial-peer to point to appropriate CM
If mgcp, just use a TP to go from CM to CME
03-16-2006 06:57 AM
Yes.
From pstn to extension direction we use a tcl script at the voice gateway.
You should use different partitions for this from extension to pstn/extension direction.
