10-09-2002 08:58 AM - edited 03-12-2019 09:06 PM
I have the following configuration and the IP phone rings, but no caller id is sent with the connection, does anyone know how to enable this?
voice-port 2/0/0
timeouts call-disconnect 3
connection plar opx 100
10-09-2002 09:56 AM
include "caller-id enable" under your voice-port configuration. Also, make sure it is an FXO-M1 VIC.
10-16-2002 04:57 PM
the caller-id enable is not a choice under the voice port, I am running 12.2.11T on a 3640. am I missing somthing?
10-16-2002 05:24 PM
If you're using an FXO port, make sure that it's a VIC-2FXO-M1 that has battery reversal for caller ID support. If you have an VIC-2FXO it will not support caller ID.
Gabriel
