MAX EAP Transmissions
exatxer
I am having an issue and cannot figure out how to fix it. At random times, I get the errors below in my WLAN Controllers and clients can no longer connect. These are not login attempts as the laptops worked on Friday and sat all weekend, now on Monday they cannot log in.
Any Ideas?
Thanks in advance
Mar 03 10:33:27.969 1x_bauth_sm.c:400 DOT1X-4-AAA_MAX_RETRY: Max AAA authentication attempts exceeded for client 00:13:02:c2:73:db
Mar 03 10:29:15.107 1x_bauth_sm.c:400 DOT1X-4-AAA_MAX_RETRY: Max AAA authentication attempts exceeded for client 00:13:02:c2:73:db
Mar 03 10:25:00.800 1x_bauth_sm.c:400 DOT1X-4-AAA_MAX_RETRY: Max AAA authentication attempts exceeded for client 00:13:02:c2:73:db
Mar 03 10:21:12.061 1x_auth_pae.c:2484 DOT1X-3-MAX_EAP_RETRIES: Max EAP identity request retries (21) exceeded for client 00:13:02:c2:73:db
ebreniz
Level 6
Level 6
This is Document and clean up error messages in the dot1x directory. Try this bug CSCsi54588
This isn't fixed on 5.0 WiSM firmware as bug search suggests.
Is there better description?
--Dan
I can't find the above bug on bug toolkit and I appear to have a controller exhibiting the same symptoms. Can anyone provide more information?
