11-13-2001 07:06 AM - edited 03-12-2019 01:20 PM
I have two connections to the PSTN. One via BRI and the second via QSIG+PBX. The Gateway is a 3640 with IOS 12.2(1a). CCM Version 3.1.2a.
In both cases when i try a call from PSTN direct to an IP Phone it works. The same from a mobil phone fails !!!
Mobil Phone via PBX and Qsig to the CCM i get several beeps and then the call is terminated.
Mobil Phone via BRI to the CCM i get a long beep and after then a message that the number is incomplete.
From an outside telephon, both numbers are working.
Have somebody similar experiences ??
Martin
11-19-2001 06:55 AM
Did you ever find out the cause of this?
11-22-2001 05:47 AM
Have had a similar problem, it turned out to be certain t3 timers that had to have their values made larger cured the problem.
The call setup time on mobiles can be longer than pstn therfore things start to time out.
will check settings and let you know. i am sure that Cisco have this document somewhere
hop this helps
11-26-2001 06:05 AM
Hi Steve,
my t3 timer values are:
t301: 180000
t302: 6000
t303: 4000
t304: 20000
t305: 30000
t306: 30000
t307: 180000
t308: 4000
t309: 90000
t310: 10000
t313: 4000
t316: 120000
t317: 300000
t321: 30000
t322: 4000
on the r3640, the value for t310 on bri interface is 40000. I never alter a timer value on the router or in ccm by hand.
thanks for your response.
martin
11-27-2001 02:08 AM
try changing the following parms on Call manager
T310 60000
MediaInterfaceCapsTimeout 40
MediaExchangeTimeout 30
sending complete indicator T
(The system we changed these on was 3.0.8)
11-27-2001 03:31 AM
I would try it again with "isdn sending-complete " on the BRI Interface.
Good Luck
Mehmet
11-27-2001 06:42 AM
i try all without success. I´ll get the same error.
After a restart from CCM-Server and the router, the connection from mobile phone via BRI works now. The changing of parameters have no more effect to the function.
My qsig config is:
interface bri1/0
no ip address
isdn switch-type basic-qsig
isdn incoming-voice voice
isdn static-tei 0
thanks
Martin
