10-30-2006 10:04 AM - edited 03-13-2019 03:35 PM
Hi everyone
I'm hoping somebody can help me!
I am trying to perform a very simple task on my CallManager, yet for some reason I am having immense difficulties!
Scenario is as follows:
I had an IP Phone with a DN of 5706. This phone was de-registered and unplugged
On the CCM, I deleted this phone (not just the DN - the entire DEVICE) and then tried to create a Translation Pattern, where the Translation Pattern=5706
For some reason, I am getting an error on the CCM saying that "There is already an existing Directory Number or pattern using the selected Partition, Route Filter combination"
I am sure there is not!!!
I have checked everywhere on the CCM, and I cannot see any other reference to this DN
I have run the Route Plan report, and it DOES list 5706 as a "device", however there is no Device Name or Description (there was before I deleted the phone)
I have also rebooted the CCM, and the problem still exists.
I am running CCM 4.1(3)sr3a
Has anyone ever seen this or have any ideas???
Bennie
10-30-2006 10:09 AM
Go to the numplan table in the CCM030X database in SQL --> Enterprise Manager. Right click on that table and select open table --> query. select the DNorRP box and under criteria put 5706, if you get a result delete that table.
10-30-2006 10:10 AM
Sorry, delete the output of that search which will be the DN.
10-31-2006 02:24 AM
Thanks for your help - managed to resolve it by doing the simplest of things:
Go to Route Plan report, list Unassigned DN's.
from there, delete your DN that is conflicting
Cheers!!!
Bennie
