Can I use the latest version of TSP with Unity Connection? Also, what is the uprgrade process to upgrade Unity Connection to the latest version with licensing similar to what they had with Connection?<br><br>Network Engineering Associates
The CM integration was never tested with Connection and we don't currently support it.
The upgrade path, unfortunately, is basically a new install. I've had at least one site use my export/import tool with connection but this isn't supported by TAC so if you have trouble with it, you'll be on your own. You can certainly try it out on a test box if you want though.
