1700 ios h323 gateway fail to register with CCM
I am trying to have 1750-2V router with 2FXS , to configure as h323 gateway, with CCM 3.3.
Router config is as follows;
interface FastEthernet0
ip address 192.168.10.1 255.255.255.0
speed auto
h323-gateway voip interface
h323-gateway voip id Call-manager multicast
h323-gateway voip h323-id 192.168.10.1
h323-gateway voip bind srcaddr 192.168.10.1
dial-peer voice 2 pots
destination-pattern 4444
port 2/1
dial-peer voice 100 voip
destination-pattern 600
session target ipv4:192.168.10.3
gateway
I can ping from the router to CCM server and vice-versa. The gateway as been defined in CCM as h323 gateway.
The router runs IOS version 12.1(5)T9.
The gateway doesn't get registered with CCM.
debug h225 asni gives following output;
value RasMessage ::= gatekeeperRequest :
requestSeqNum 8
protocolIdentifier { 0 0 8 2250 0 2 }
rasAddress ipAddress :
ip '09BB6346'H
port 54237
endpointType
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
gatekeeperIdentifier {"Call-manager"}
endpointAlias
e164 : "3333",
e164 : "4444"
RAW_BUFFER::=
00 A0000706 0008914A 00020009 BB6346D3 DD088001 3C050100 05800043 0061006C 006C002D 006D0061 006E0061 00670065 00720201 80666601 807777
00:05:34: PDU DATA = 80DF5C9C
Any ideas as to what has gone wrong ?
Silver
Re: 1700 ios h323 gateway fail to register with CCM
It is normal for an H323 gateway to not get registered with Callmanager. Unlike MGCP (client-server model), H323 is a peer-to-peer protocol and hence the gateways do not register with Callmanager.
For Call adminssion control and bandwidth control, you can have the H323 gateway register with a H323 gatekeeper. Callmanager does not do any gatekeeper functionality. You can use a router with Gatekeeper image for that functionality.
In your configuration, you have configured a gatekeeper with the command
If you do not have a gatekeeper in your network, you can remove this command.
Try placing a call from the analog phone to an IP phone and see how it goes.
Silver
First of all if you are adding this gateway to CCM, then the config doesn't look correct. Change your config to this:
speed auto
port 2/1
In CCM add the gateway as h323 using Device Name 192.168.10.1. Remember that the Registration will always show unknown on the CCM, but you should get 192.168.10.1 in the IP Address status.
The debug that you were doing and most of the commands is used when you will register this gateway to a gatekeeper.
Partha
Many thanks for both Partha and Anand !
As you very correctly stated, I can only see the IP address of the gateway in CCM, but the status is "unknown". Therefore I was trying to make it available to CCM.
But I can now place the calls for IPtel domain to Analog domain, vice-versa !
Thanks again !
178
