2 Callmanager connected to a getekeeper for CAC
gatekeeper
zone local bombay abc.com 10.10.10.50
zone local delhi abc.com
bandwidth interzone zone bombay 300
bandwidth interzone zone delhi 300
bandwidth total zone bombay 300
no shutdown
I have 2 callmanagers running 3.2, they both r using inter cluster trunk to talk to each other and they r also registered to a gatekeeper(config pasted above).
I can route calls through the intercluster trunk when the gatekeeper is not registered with the call managers. but when the gatekeeper is registered withboth the call managers the call does not go through. both the call managers are in zones delhi and bombay, I have used the concept of location and region, but I suppose that is not the problem, the problem is in the gatekeeper config.
1 REPLY
Silver
Re: 2 Callmanager connected to a getekeeper for CAC
You cannot run intercluster reunks and Gatekeepers together. This seems to be somewhat of a design issue. WHat are you trying to do and what is your goal?
Taimoor
131
