2 Dial-peer, same extension
How can I configure 2 dial-peers with the same extension number, all calls will go to the first phone, and the call will only go to the second phone when the first phone is busy.
Thank you in advance.
  • Other Collaboration Voice and Video Subjects
Re: 2 Dial-peer, same extension
You didn't specify pots or voip so I will assume voip
dial-peer voice 1 voip
 destination-pattern 1234
 preference 2
 session target ipv4:10.1.1.3
dial-peer voice 2 voip
 preference 4
You may wish to investigate the dial-peer hunt global configuration command which alters the way IOS searches dial-peers for matches.
Use the preference command. 0 is the highest (default). Here's an example:
dial-peer voice 1 pots
destination pattern 123
port 1/0/0
preference 0
dial-peer voice 2 pots
port 1/0/0
preference 1
99
