2 PRI Trunks On 1 Controller
a customer of mine has a 1-port MFT VWIC on his 2811 router and a CCM cluster. What he wants to achieve is to create two separate trunks with 9 b channels each, where 1 set of chanels would be used for one company exclusively, and the other set of channels for a different company. Is something like this possible with Cisco gateways?
Dragi
  • Other Collaboration Voice and Video Subjects
1 REPLY
Bronze
Re: 2 PRI Trunks On 1 Controller
You can easily create 2 seperate channel groups when using a voice T1 with Channel associated signalling. Under the T1 controller you would configure the two seperate DS0-groups. For example:
DS0-group 0 timeslots 1-9 type E&M-fgb dtmf dnis
DS0-group 1 timeslots 10-18 type E&M-fgb dtmf dnis
this would create two seperate T1 voice ports using 9 channels each.
see the following link for more on Voice T1 CAS configuration:
http://www.cisco.com/en/US/partner/tech/tk652/tk653/technologies_configuration_example09186a00800fa115.shtml
88
