2 pstn specific outbound calls
hi,
i have one gateway router 2621 for ccm outbound calls, i need configure specific outbound calls for E1 because in one E1 only have 100 calls to long distance and other E1 200 calls.
router gateway with two e1 with 20 channels to pstn with diferent carrier.
i have only this configuration in the router:
sccp local FastEthernet0/0.10
sccp
sccp ccm 192.168.10.5 priority 1
sccp ip precedence 3
Re: 2 pstn specific outbound calls
I'm not sure of your exact question, but here are a couple of links regarding setting up MGCP/H.323 gateways with Callmanager.
How to Configure MGCP with Digital PRI and Cisco CallManager
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
Cisco IOS H.323 Gateway Configuration for Use with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Hope this helps. If so, please rate the post.
Brandon
Green
Mmm, This is not possible in CCM, you may check that will your Telco so they restrict that.
Normally you restrict either call duration or Long Distance access. Telco should be able to do this.
then, i can only balancing outbound calls with preference in dial-peer...?
Even i m not clear abt ur question but i think you need to read some stuff about MGCP configuration, Route pattern, route list , route group...that should help you.
the router not support mgcp becauso is E1 to pst configured in R2 not isdn or ss7.
143
