Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
250 location for Callmanager 5.1(2b)
I have configured 300 location in one cluster with CKM 5.1.2b, when i try to configure the location for one gateway, in the location option i am only allowed to selec from the first 250 and i dont have the fin option to select the other 50.
Does any one have the same problem?
1 REPLY
Bronze
Re: 250 location for Callmanager 5.1(2b)
I think max 250 location are allowed in CCM 5.1.
Be aware that the release of Cisco IP telephony products does not always coincide with Cisco Unified CallManager releases. If a product does not meet the compatibility testing requirements with Cisco Unified CallManager, you need to wait until a compatible version of the product becomes available before you can upgrade to Cisco Unified CallManager release 5.1(1x). For the most current compatibility combinations and defects that are associated with other Cisco Unified Communications products, refer to the documentation that is associated with those products.
101
