2500's and Ip Telephones
Whilst I know 2500's are more or less discontinued most of us have a few thousand spare in our network cupboards !
My query is that i Can get IP telephones working very nicely across two recently purchased 2600 routers ( with no QofS as I have loads of bandwidth ) but the phones will not work if I exchange one of the 2600's for a 2500.( I get one-wat Transmission ) The configurations are identical .
I assume that this is because the 2500 is either not listening to all UDP ports or one of the h323 ports . Whilst I could trace this and find out I do not have the time . Does anyone know the answer ?
Blue
Re: 2500's and Ip Telephones
It really sounds like a basic IP routing issue. Have you tried pinging the phones from all routers that are in the end to end path?
Nah its not routing
Silver
If they are acting as a pure IP router, the 2500's will not be looking at TCP or UDP ports - they shoul djust be forwarding packets.So there must be something else going on... Can we see the configs of the 2600's and 2500's to compare them ?
92
