2600XM - NM-HD-2V or 2VE with CCME and AIM-CUE?
I looking at a 2600XM with CCME 3.1 and AIM-CUE and using either the NM-HD-2V or 2VE module with VIC-4FXS/DID and was wondering if the FXS ports have to have PVDM like a AIM-VOICE-30 card so that the FXS cards terminate to?
I do not believe that you need it, but I want to make sure.
Thanks in advance!
Re: 2600XM - NM-HD-2V or 2VE with CCME and AIM-CUE?
The NM will have the DSP resources for the VICs, so you won't need an AIM card... Depending on the codec you use, you might be able to support only 6 simultaneous calls with the HD-2V card, so that might be something to think about if you're trying to put 2 of the 4FXS vics in that NM...
John
No, the VIC card inside the NM-HD-2V will use the fixed DSPs populated on the NM-HD-xx card. No need for extra DSPs.
CH
Thank you for the quick reply, I thought so but wanted to make absolutely sure.
151
