2621XM, AIM-Voice-30, VWIC-MFT-E1, CCM3.2 -> MGCP or H.323?
i think the title tells it all. How do i configure the voice gateway from ccm with the components described above?
I think, MGCP shoul be possible but when we choos 26xx-gateway in the "add mgcp gateway" dialog there is no chance to enter Slot0 as destination for the voice int. Any hints or solution? Thanks.
Silver
Re: 2621XM, AIM-Voice-30, VWIC-MFT-E1, CCM3.2 -> MGCP or H.323?
AIM voice 30 does not have MGCP support yet. You will need to run H323
Thanks for information. We will use H323 and wait for the mgcp support...
Is it so difficult or so unimportant to support those configurations (belongs also to all kind of bri connections - we are from germany...)?
Silver
The AIM is easy to use and will give up to 30 voice channels on a PRI interface. If you want to run BRI, you will need a NM-2V and a BRI VIC card as well as the AIM is only designed to work with a E1/T1 VWIC card.
137
