Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
26XX and36XX MGCP Configuration
Does anyone have a sample configuration for setting up a 2600 or 3600 as an MGCP gateway?
Re: 26XX and36XX MGCP Configuration
I don't believe the 2600's or 3600's run MGCP yet. They may in some version of 12.1. Here is a sample from a VG200:
[OK]
VG200-IMCBP-GW1#term len 0
VG200-IMCBP-GW1#sh run
Building configuration...
Current configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname VG200-IMCBP-GW1
enable secret 5 $1$o1cZ$rbWB4yjTm29aEfooZypat.
ip subnet-zero
no ip domain-lookup
mgcp
mgcp call-agent 10.10.19.19
mgcp dtmf-relay codec all mode out-of-band
mgcp sdp simple
mgcp ip-tos precedence 5
mgcp default-package hs-package
ccm-manager switchback graceful
ccm-manager redundant-host 10.10.19.18
ccm-manager mgcp
interface FastEthernet0/0
ip address 10.40.4.15 255.255.255.0
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.40.4.1
no ip http server
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
dial-peer voice 1 pots
application MGCPAPP
port 1/0/0
dial-peer voice 2 pots
application MGCPAPP
port 1/0/1
dial-peer voice 3 pots
application MGCPAPP
port 1/1/0
dial-peer voice 4 pots
application MGCPAPP
port 1/1/1
line con 0
password 7 020856551D12
logging synchronous
login
transport input none
line aux 0
line vty 0 4
password 7 11074B0B0106
login
no scheduler allocate
end
Thanks for the info although I have 12.1 (5)T on a 2600 with Call Manager 3.1 (5a). The 2600 has all the MGCP commands listed, I've just never seen them before and the Cisco web site doesn't have anything on it yet for the 26XX or 36XX.
Anonymous
N/A
The 2600 and 3600 does support MGCP (version 0.1). IOS 12.1.5T (the one you have) has support for MGCP.
See foll URL for more info. (command reference and configs ...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t3/mgcp1213.htm
-anand
Thanks. This is exactly what I was looking for.
I'm trying to do the same but when entering the line item application MGCPAPP it does not register in upper case and I was told that this is crucial.
The router is registering with the CM but when I dial 9 to grab a line I get fast busy.
Entering application MGCPAPP in all upper case is not necessary... there was a minor parser bug in an early release of software. The problem is more likely in the MGCP registration.
If you do a show ccm on the router, I believe the first or second line of output will tell you the MGCP Domain Name. This is made up of the router hostname and router domain-name from the IOS config. Whatever this says, even if it's not in DNS, that's exactly what it needs to say for the MGCP Domain Name in the device configuration for the gateway on the CallManager. Make sure it's the same, reset the device in CallManager, and reload the router if possible.
If it's still not working, open a TAC case and be prepared to send:
- output of show running
- output of show version
- output of show ccm
- output of debug mgcp packet
- CCM trace file from the CallManager with Detailed tracing enabled.
thanks man - that did the trick!
Much appreciated.
Paul.
I am having trouble with MGCP on a 3640 running 12.1.5T(7). The cmm-manager command is not available. Do I have the right IOS??
Here is my config
RT1_MMT_BNE#sh run
Current configuration : 2650 bytes
version 12.1
no service single-slot-reload-enable
hostname RT1_MMT_BNE
logging rate-limit console 10 except errors
enable password cisco
voice-card 1
ip subnet-zero
ip cef
no ip finger
no ip domain-lookup
ip dhcp excluded-address 192.168.100.1 192.168.100.49
ip dhcp pool 1
network 192.168.100.0 255.255.255.0
option 150 ip 192.168.100.10
default-router 192.168.100.1
mgcp
mgcp call-agent 192.168.100.10
isdn switch-type primary-net5
isdn voice-call-failure 3
isdn alert-end-to-end
call rsvp-sync
no voice hunt unassigned-number
no voice hunt invalid-number
voice rtp send-recv
voice service voip
h323 call start fast
voice class codec 100
codec preference 1 g711ulaw
codec preference 3 g729r8
controller E1 1/0
framing CRC4 Australia
pri-group timeslots 1-10,16
translation-rule 1
Rule 1 ^0.% 000
Rule 2 ^2.% 002
Rule 3 ^3.% 003
Rule 4 ^4.% 004
Rule 5 ^6.% 006
Rule 6 ^7.% 007
Rule 7 ^9.% 009
translation-rule 2
Rule 1 ^9.% 32909
interface Loopback0
no ip address
description MTE_BNE LAN
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description Managment vlan
encapsulation isl 1
ip address 192.168.10.1 255.255.255.0
no ip redirects
interface FastEthernet0/0.2
description Voice Vlan
encapsulation isl 100
ip address 192.9.100.101 255.255.255.0
no ip redirects
interface FastEthernet0/0.3
encapsulation isl 200
ip address 192.168.100.1 255.255.255.0
no ip redirects
interface Serial1/0:15
no ip address
no ip route-cache cef
no logging event link-status
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.9.100.254
no ip http server
voice-port 1/0:15
cptone NZ
timeouts interdigit 2
music-threshold -48
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/1/0
voice-port 2/1/1
dial-peer cor custom
dial-peer voice 100 pots
destination-pattern 0
progress_ind alert enable 1
progress_ind connect enable 1
translate-outgoing calling 2
direct-inward-dial
port 1/0:15
dial-peer voice 200 voip
destination-pattern 9
voice-class codec 100
session target ipv4:192.168.100.10
dtmf-relay h245-alphanumeric
ip precedence 5
no vad
dial-peer voice 300 pots
application mgcpapp
port 2/0/0
dial-peer voice 301 pots
application mgcpapp
port 2/0/1
dial-peer voice 302 pots
application mgcpapp
port 2/1/1
line con 0
line aux 0
line vty 0 4
password cisco
login
end
RT1_MMT_BNE# sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.1(5)T7, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 16-Apr-01 20:24 by ccai
Image text-base: 0x60008950, data-base: 0x61142000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3640-IS-M), Version 12.1(5)T7, RELEASE SOFTWARE (fc1)
RT1_MMT_BNE uptime is 2 hours, 8 minutes
System returned to ROM by reload
System image file is "flash:c3640-is-mz.121-5.T7.bin"
cisco 3640 (R4700) processor (revision 0x00) with 124928K/6144K bytes of memory.
Processor board ID 25117033
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
11 Serial network interface(s)
1 Channelized E1/PRI port(s)
2 Voice FXO interface(s)
2 Voice FXS interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
RT1_MMT_BNE#
Darren
I offer no help as I am having the same problem.....I am very interested in the solution..Maybe Dave from Cisco can help here?
You need 12.1.5.XM2 it then supports the ccm-manager command and all starts working!!!
Rgds
Darren
211
