Community Member
2801 Dropping Calls and losing dial tone
I have a 2801 that will periodically drop a phone call and after dropping the call i get no dial tone. I have to reboot the router to solve the problem.
IOS version - c2801-spservicesk9-mz.124-7b.bin
one vic-4fxs
one vic2-2fxs
config
Current configuration : 2958 bytes
version 12.4
hostname DTS_222
boot-start-marker
boot system flash c2801-spservicesk9-mz.124-7b.bin
boot-end-marker
enable secret xxxx
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp excluded-address 192.168.1.150 192.168.1.254
ip dhcp pool RemoteVSAT
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 10.1.23.1
ip domain name dtscom.local
voice-card 0
interface FastEthernet0/0
ip address 10.1.23.10 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.1.23.1
no ip http server
no ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 remark Exclude traffic for NAT
access-list 100 deny ip 192.0.0.0 0.255.255.255 10.129.0.0 0.0.255.255
access-list 100 deny ip 192.0.0.0 0.255.255.255 10.127.0.0 0.0.255.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
snmp-server community dts200 RO
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/3/0
voice-port 0/3/1
ccm-manager redundant-host 10.129.0.8
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.129.0.8
ccm-manager config
mgcp
mgcp call-agent 10.129.0.9 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp codec g729r8 packetization-period 60
mgcp playout fixed 250
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 9600
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
line con 0
password xxx
logging synchronous
login
line aux 0
line vty 0 4
password xxx
logging synchronous
login
line vty 5 15
password xxx
logging synchronous
login
1 REPLY
Bronze
Re: 2801 Dropping Calls and losing dial tone
Sounds like a cabling issue. But could be something else. If you get no dial tone it means phone is not talking to Call Manager.
If only one phone is having this issue I'd say check the cabling. If multiple phones are affected start with Call Manager traces to check keepalives.
133
