2811 - Right fax - dial-peer / num-exp question
Hi I have a 2811 with 2 PRI and I have a little question regarding the configuration of a num-exp and dialp-peer with right fax.
here is my actual config
dial-peer voice 5555555512 voip
destination-pattern 5555555512
session target ipv4:192.168.0.34
incoming called-number 5555555512
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
With no num-exp it is working fine.
Right now the problem is I have a dial-peer for every Fax, I would like to minimize the configuration and instead use only one dial peer and have a num-exp or something else that take the call-fax and give it to the dial peer,   if it's possible.
ex:
num-exp 5555555512 8000
num-exp 5555555513 8000
num-exp 5555555514 8000
num-exp 5555555515 8000
dial-peer voice 8000 voip
destination-pattern 8000
incoming called-number 8000
codec g711ulaw
*of course I have try that and It is not working, well the tech on site told me he did'nt recived the fax in the department mailbox.
Maybe because right fax wasn't able to see the Called-number and give that to the right department mail-box.
any idea ?
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 2811 - Right fax - dial-peer / num-exp question
you cannot replace the called number like that and expect things to work.
If your numbers can be summarized with pattern in destination-pattern, you can do that.
otherwise you need to keep on DP per number, and tha is not a problem whatsoever.
thanks a lot
1065
