2950 and IP phones...No connectivity for PC's
Phones work...PC's don't....Any ideas? I add the PC to a static access port and I can ping everything. Same config on a 3550-24 works fine...weird....Oh, and the "switchport trunk encap dot1q" command is NOT available on this platform...even more weird....
Switch To Phone:
interface FastEthernet0/1
description IP phone and PC
switchport trunk native vlan 7
switchport mode trunk
switchport voice vlan 17
switchport priority extend cos 5
no ip address
Switch trunk to router:
interface FastEthernet0/12
description Trunk to 1760 router
no ip address
Router interface:
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.7
encapsulation dot1Q 7 native
ip address 192.168.7.254 255.255.255.0
interface FastEthernet0/0.17
encapsulation dot1Q 17
ip address 192.168.17.254 255.255.255.0
Re: 2950 and IP phones...No connectivity for PC's
Auto negotiation is junk on these switches. Hardcode 100/full and you'll be working fine.
Try adding switchport access vlan 7 (in your case) to the ports as well and this should fix your issues if you still have them. I had similar issues and this resolved my problems by setting both the native and the access VLAN to be the same. If you have PC's that you setup trunking on in software, the access vlan 7 is not necessary. If you are using your PC's as just that, static access, you will need to add this command if I am not mistaken.
Please someone correct me if I am wrong.
Matt
113
