08-07-2002 07:25 AM - edited 03-12-2019 08:15 PM
Is the installation of Unity3.14 same as 3.13? I couldn't find the installation documentation for 3.14,can I assume they are same?
08-07-2002 07:37 AM
Yes they are the same.
Keith
08-07-2002 07:47 AM
how about those service pack, such as SQL, NIMDA, and so on? Because I see there are 2 service pack CD for 3.14 in the Cisco software downloading center. For 3.13 is only one SP Cd, is there any difference?
08-07-2002 09:26 AM
All the information you need can be found in the install guide and release notes for 3.1.4:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/inst/inst31/index.htm
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/rel_note/index.htm
adam
08-07-2002 10:32 AM
I see. Do I have to run exchange 2000 SP2 in unity if the unity only installed administration software only?
08-07-2002 10:41 AM
No but it is a good idea.
Keith
