11-05-2001 09:56 AM - edited 03-12-2019 01:11 PM
What am I doing wrong? I have two Vlans, (120 - Office PC's) (125 - Office Phones)
I have an office of 7960 Phones. I would like the PC port on the phone to be Set to vlan 120 and the phone obviously to talk on vlan 125.
I have tried the following commands the phone never registers or works. Set the switch port to straight vlan 125 and the phone registers right up.
>int f0/6
>switchport voice vlan 125
>switchport access vlan 120
What is wrong with this?
11-05-2001 10:42 AM
Assuming the basics - you have separate subnets on vlans 120 and 125 with routing between them. You also have the DHCP scopes for both vlans set up correctly with the router and option 150 set on both and CallManger on the appropriate vlan/IP subnet - logically it should be 125
I believe the correct set up should be, with the IP phone beinga switch in its own right runing 802.1q:
interface fa 0/6
switchport trunk encap dot1q
switchport mode trunk
11-05-2001 10:51 AM
interface FastEthernet0/2
switchport trunk native vlan 120
