Community Member
3550 port issue
have a customer that every couple of weeks his fa/09-fa/12 ports have bounced – they are in a down/down state for no apparent reason. They are trunked and have IP phones off each one – as do the others.
here is part of his log:
Log Buffer (4096 bytes):
no longer detected on port Fa0/9, port set to untrusted.
000607: Feb 2 20:21:25.374: %LINK-3-UPDOWN: Interface FastEthernet0/10, changed state to down
000608: Feb 2 20:21:25.374: %TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/10, port set to untrusted.
000609: Feb 2 20:21:25.390: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to down
000610: Feb 2 20:21:25.390: %TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/11, port set to untrusted.
000611: Feb 2 20:21:25.410: %LINK-3-UPDOWN: Interface FastEthernet0/12, changed state to down
000612: Feb 2 20:21:25.410: %TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/12, port set to untrusted.
000613: Feb 2 21:18:23.587: %SYS-5-CONFIG_I: Configured from console by vty3 (172.24.104.9)
000614: Feb 2 21:19:24.593: %SYS-5-CONFIG_I: Configured from console by vty4 (172.24.104.9)
000615: Feb 2 21:25:33.416: %SYS-5-CONFIG_I: Configured from console by vty1 (172.24.104.9)
000616: Feb 2 21:29:24.888: %LINK-5-CHANGED: Interface FastEthernet0/9, changed state to administratively down
000617: Feb 2 21:29:31.192: %LINK-3-UPDOWN: Interface FastEthernet0/9, changed state to down
000618: Feb 2 21:29:35.328: %LINK-3-UPDOWN: Interface FastEthernet0/9, changed state to up
000619: Feb 2 21:29:37.340: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/9, changed state to up
000620: Feb 2 21:29:45.213: %LINK-5-CHANGED: Interface FastEthernet0/10, changed state to administratively down
000621: Feb 2 21:29:48.681: %LINK-3-UPDOWN: Interface FastEthernet0/10, changed state to down
000622: Feb 2 21:29:48.837: %TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/9, port trust enabled.
000623: Feb 2 21:29:52.861: %LINK-3-UPDOWN: Interface FastEthernet0/10, changed state to up
any ideas as to what is causing this?
Community Member
Re: 3550 port issue
Is he using inline power? Tell him to take those ports from power inline autonegotiate to hardset.
Community Member
Re: 3550 port issue
how do you do this? It's either Auto or
Never. What is the command to hand-set this option?
112
