3640 H323 gateway and CallManager 3.0(8)
kafambo
I have one 3640 H323 GW with FXS analog interfaces and another one with Digital PRI interfaces
Q1/ Is it possible to use H323 GW with CCM 3.0(8) ?
If yes,
Q2/ How can I configure manual tftp server on the GW ?
rokibbe
Q1 - yes, it's possible
Q2 - why do you need one? When you load an IOS image with the COPY TFTP FLASH command, you'll be entering the TFTP server's address there.
kafambo
THX for your reply.
for Q2, normaly, you need to configure (manual or with DHCP) a tftp server which store device default config file to register the device with CallManager.
Anyway, the problem is resolved
