3640 PRI connect to Verizon!!
Is there anyone can share configuration for 3640 with PRI?? Can I use same 3640 for gatekeeper?? Do I need to buy another 3600 series for Gatekeeper??
We are going to setup 3 sites in NYC with 1 Cluster(CallManager), 100 IP Phones 7960, and Two 3640 with PRI connect to Verizon.
We try to make user to allow to call VoIP to VoIP and VoIP to PSTN -->I know we can do that. However can someone from another company or home call back to VoIP (PSTN to VoIP)???? If can, how to do it??
Thanks a lot!!!
1 REPLY
Re: 3640 PRI connect to Verizon!!
here is a 3640 PRI config
I have never done gateway and gatekeeper on the same device but i beleive i have read it can be done.
Password:
GW>en
Password:
#sh run
Building configuration...
Current configuration : 3147 bytes
version 12.2
service timestamps log uptime
service password-encryption
hostname
enable secret
voice-card 1
ip subnet-zero
no ip domain-lookup
isdn switch-type primary-5ess
voice service pots
fax interface-type fax-mail
mta receive maximum-recipients 0
controller T1 1/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 192.168.1.235 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 192.168.1.235
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
no cdp enable
no ip classless
ip route 0.0.0.0 0.0.0.0 192.9.250.254
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 192.9.250.0 255.255.255.0 192.168.1.100
ip route 192.168.1.0 255.255.255.0 192.9.250.254
no ip http server
ip pim bidir-enable
call rsvp-sync
voice-port 1/0:23
echo-cancel coverage 32
timeouts interdigit 5
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/1/0
voice-port 2/1/1
voice-port 3/0/0
supervisory disconnect anytone
voice-port 3/0/1
timeouts call-disconnect 2
connection plar 0763
description inbound_fxo
voice-port 3/1/0
connection plar 0760
voice-port 3/1/1
connection plar 0132
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 9T
direct-inward-dial
port 1/0:23
dial-peer voice 6000 voip
destination-pattern 7...
session target ipv4:192.168.x.x
codec g711ulaw
dial-peer voice 3000 voip
destination-pattern 3...
progress_ind setup enable 3
session target ipv4:192.168.1.240
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 6001 voip
destination-pattern 6...
codec g711ulaw
dial-peer voice 9999 voip
destination-pattern 0...
codec g711ulaw
dial-peer voice 1000 voip
destination-pattern 1...
codec g711ulaw
dial-peer voice 132 voip
destination-pattern 0132
dial-peer voice 4 voip
destination-pattern 622....
codec g711ulaw
dial-peer voice 760 voip
destination-pattern 0760
codec g711ulaw
dial-peer voice 616 voip
destination-pattern 616....
codec g711ulaw
dial-peer voice 763 voip
destination-pattern 0763
codec g711ulaw
gateway
gatekeeper
shutdown
line con 0
line aux 0
password 7
speed 56000
line vty 0 4
password 7
login
end
GW#
292
