3745 MGCP Cannot call out HELP!
I have a 3745 with IOS 12.3(6) running IP PLUS. I have 2 - NM-HDV with 2 2MFT-T1 cards in each. I only have controller T1 1/0 operational at this time.
Therefore I have interface Serial 1/0:23 and Voice-Port 1/0:23
I have the dial-peer 10 voice pots
incoming called number.
destinationa pattern 9T
application mgcpapp
direct-inward-dial
port 1/0:23
The L2 of the PRI is up Mutliple Frames Established.
I have all my Route Patterns tied to Route Filters.
9.@ LongDistancePT LongdistanceRF PreDot
I try to make a call to the PSTN and it drops the call immediately.
I looked at the debug ISDN q931 and saw that I was sending out the appropriate numbers and it was not sending the nine.
It was working for a short while, I tried to make some changes because when trying to see if SRST was working there was NO dial-tone. After making minor changes, it stopped working again even with CCM up.
I TFTP the working config back and still it disconnects the call immedaitely.
Should I use 12.3(7)T IP VOICE instead of the IP PLUS?
  • Other Collaboration Voice and Video Subjects
Re: 3745 MGCP Cannot call out HELP!
Could you post the whole config. I have worked with a 3745 and currently 3725 and can make calls out without any problems. So it may be a simple configuration thing.
As soon as I get the configs I will send them to you just send send me your e-mail address to bhenry33@adelphia.net
Thanks!
93
