05-23-2009 04:42 PM - edited 03-13-2019 06:23 PM
we has create a environment base on CME 7.0 and 3951, 7940 phones. 3951 registe to cme success. but when 3951 place call to another phone, was very slowly. but 7940 place call to 3951 was faster. who know what problem happen?
very thanks
Solved! Go to Solution.
05-26-2009 04:18 PM
The reason they are different is because they are running completely different protocols. Your 7940/70 is running SCCP and your 3951 is running SIP.
Based on the way SIP works your phone is not going to get the complete dial plan on every digit because SIP sends digits enbloc rather than digit by digit.
You can load the dial plan to the phone like this:
voice register dialplan 1
pattern 1..
pattern 2..
voice register pool 1
dialplan 1
voice register global
create profile
reset
-nick
05-24-2009 10:34 PM
Is it happening with internal call or for the PSTN calls ?
Can you attach the show run from the router ?
~Neeraj
05-24-2009 11:42 PM
was internal call very slow, PSTN Call not test yet.
follow is sh run:
Test-VG3845#sh run
Building configuration...
Current configuration : 4771 bytes
version 12.4
hostname Test-VG3845
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/3
logging message-counter syslog
logging buffered 512000
enable secret 5 $1$RdRQ$/z0qcYWroETxtJLlhIXNJ0
no aaa new-model
clock timezone BeiJing 8
ip source-route
ip cef
ip dhcp excluded-address 10.62.54.1 10.62.54.15
ip dhcp pool Voice
origin file flash:/static-bindings.txt
default-router 10.62.54.1
option 150 ip 10.62.54.1
dns-server 10.62.54.1
no ip domain lookup
no ipv6 cef
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 600 min 60
mode cme
source-address 10.62.54.1 port 2000
max-dn 720
max-pool 262
load 3951 SIP3951.8-1-1b
timezone 42
time-format 24
create profile sync 0004418369708934
ntp-server 10.62.54.1 mode directedbroadcast
voice register dn 201
number 201
name WJ-201
voice register dn 202
number 202
name WJ-202
voice register dn 203
number 203
name WJ-203
voice register dn 204
number 204
name WJ-204
voice register dn 205
number 205
name WJ-205
voice register dn 206
number 206
name WJ-206
voice register pool 201
id mac 000A.8AFF.F76C
type 3951
number 1 dn 201
username 201 password cisco
voice register pool 202
id mac 000A.8AFF.F7E1
type 3951
number 1 dn 202
username 202 password cisco
voice register pool 203
id mac 000A.8AFF.F4AE
type 3951
number 1 dn 203
username 203 password cisco
voice register pool 204
id mac 000A.8AFF.FA01
type 3951
number 1 dn 204
username 204 password cisco
voice register pool 205
id mac 000A.8AFF.F58F
type 3951
number 1 dn 205
username 205 password cisco
voice register pool 206
id mac 000A.8AFF.FA77
type 3951
number 1 dn 206
archive
log config
hidekeys
05-24-2009 11:43 PM
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.128.135.77 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.12
encapsulation dot1Q 12 native
ip address 10.62.53.1 255.255.255.0
interface GigabitEthernet0/1.112
encapsulation dot1Q 112
ip address 10.62.54.1 255.255.255.0
interface Integrated-Service-Engine4/0
no ip address
shutdown
!Application: CUE Running on NME
no keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.128.135.1
ip http server
ip http path flash:gui
tftp-server flash:P00308000500.bin
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sb2
tftp-server flash:P00308000500.sbn
tftp-server flash:BOOT3951.0-0-0-9.zz
tftp-server flash:DSP3951.0-0-0-2.zz
tftp-server flash:SIP3951.8-1-1-4.zz
tftp-server flash:SIP3951.8-1-1b.loads
tftp-server flash:ATA030203SCCP051201A.zup
tftp-server flash:static-bindings.txt
tftp-server flash:apps70.8-4-1-23.sbn
tftp-server flash:cnu70.8-4-1-23.sbn
tftp-server flash:cvm70sccp.8-4-1-23.sbn
tftp-server flash:dsp70.8-4-1-23.sbn
tftp-server flash:jar70sccp.8-4-1-23.sbn
tftp-server flash:SCCP70.8-4-2S.loads
tftp-server flash:term70.default.loads
tftp-server flash:S00105000300.sbn
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
telephony-service
em logout 0:0 0:0 0:0
max-ephones 262
max-dn 720
ip source-address 10.62.54.1 port 2000
ip qos dscp af11 media
ip qos dscp cs2 signal
ip qos dscp af43 video
ip qos dscp 25 service
load 7914 S00105000300
load 7960-7940 P00308000500
load 7970 SCCP70.8-4-2S
load ata ATA030203SCCP051201A
time-zone 42
time-format 24
max-conferences 12 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 octo-line
number 100
name WenJun 100
ephone-dn 110 dual-line
number 110
name WenJun 110
ephone-dn 151 dual-line
number 151
name WenJun 151
ephone 100
mac-address 0024.C4BE.27DE
speed-dial 10 110 label "110"
type 7970 addon 1 7914
button 1:1 10:151 12:110
ephone 110
mac-address 0024.C4FE.7F7A
type 7940
button 1:110
ephone 151
mac-address 0024.97A9.2CBF
max-calls-per-button 2
type ata
button 1:151
line con 0
line aux 0
line 258
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
ntp server 10.62.54.1 prefer
end
Test-VG3845#
05-25-2009 01:43 AM
Can you recheck if its the phone dialing slowly or the numbers.
I mean if you dial a number starting with 1xx is it slow or 2xx
Try interchanging a numbers with phone and let me know the exact details.
for example
101(7940 phone ) dial 201 (3911 phone ) slow etc
05-25-2009 07:49 PM
110(7940)->100(7970) fast
100(7970)->201(3951) fast
202(3951)->201(3951) slow
202(3951)->100(7970) slow
05-25-2009 10:13 PM
Thanks for the reply
However can we have a scenario like
202(7940) to 201(7940) ?
05-25-2009 11:40 PM
202 & 201 was 3951
3951 ip phone -> 3951 ip phone slow
7940 ip phone -> 7940 ip phone fast
05-26-2009 03:30 AM
right ..is it possible to change the dn's
I mean swap the dn(number/extension) for 7940 and 3911
Can u put 202 on a 7940 phone and check ..
05-26-2009 04:18 PM
pattern 1..
pattern 2..
dialplan 1
create profile
reset
-nick
05-26-2009 10:10 PM
very thanks your help.
we add dialplan to register pool follow your steps, the delay still about 5 seconds. that's normal? and in voice regoster dialplan, we must indicate type "7905-7912" or "7940-7960-others", so i set to "7905-7912", that's right?
and i think the problem did related to "interdigital timeout" ?
05-27-2009 04:36 AM
I haven't made a dial plan for the 3951 before, but I would just test them all until one works. Make sure that you go back to voice register global and 'create profile' to update the files that get downloaded to the phone each time.
But yes, the problem is the interdigit timeout.
-nick
06-17-2009 11:48 PM
very thanks your help. we had resolved the problem. and we find the timeout interdigital command and voice register dialplan was mutex, that's normal?
06-18-2009 12:01 AM
"was mutex" ???
Which language is that ?
