4 Seconds of Dial Tone Messages
Running Unity 3.1.6 in a dual PBX/Call Manager integration. This seems to appear mostly on the PBX side. At least that is where I can reproduce it. When people hang up after receiving a voicemail greeting, and not wanting to leave a message, Unity records roughly 4 seconds of dial tone and delivers it as a message. Is there a parameter I can adjust to get rid of these types of erroneous messages?
Thanks again!
1 ACCEPTED SOLUTION
Re: 4 Seconds of Dial Tone Messages
Ok, since the caller is hanging up while the call is connected then we should be able to get reliable loop-current disconnect from the PBX. Make sure that Adjunct Supervision is enabled for each of the station lines going to Unity. With this, Unity should be able to drop its end of the call before any disconnect tone is played.
Gold
There are a fews ways this could be happening. When this happens are the callers hanging up after the record beep, during the subscriber's greeting or are before Unity even answers the phone?
Also, what PBX are you connected to? And does your active switch file contain definitions for [Switch Disconnect Tone] and/or [CO Disconnect Tone]? If so, can you post those sections of your switch file here?
-Eric
This problem seems to occur when the caller hangs up while hearing the greeting. We are using an Avaya G3R V9.5 PBX. Here is what the Avaya001.ini file looks like.
$COPYRIGHTSTART ********************************************************
; Copyright © 1998-2001 Cisco Systems, Inc. All rights reserved.
; This product is protected by one or more of the following US patents:
; 5,070,526; 5,434,906; 5,488,650; 5,533,102; 5,568,540; 5,581,604;
; 5,625,676; 5,651,054; 5,940,488; 6,041,114. Additional US
; and foreign patents pending.
; Unity and ActiveAssistant are trademarks of Cisco Systems, Inc.
; Cisco Systems, Inc.
; San Jose, California
; U.S.A.
; $COPYRIGHTEND **********************************************************
; NOTE: Enter values for "DelayBeforeOpening" and "RetryInterval" in seconds.
; Enter all other timing parameters in milliseconds.
[Identity]
SwitchManufacturer=AVAYA
SwitchModel=DEFINITY GX
SwitchSoftwareVersion=ALL
IntegrationType=Serial
[Configuration]
DelayBeforeOpening=0
Integration=SMDI
ConfirmReturn=
TransferInitiate=&,
BusyRecall=&,&
Recall=&,&
PauseDuration=1000
PulseBreakInterval=60
PulseMakeInterval=40
PulseDialInterDigitDelay=1000
ToneDialInterDigitDelay=50
DigitToneDuration=100
DTMFDebounce=40
MinimumRingOnInterval=100
MinimumRingOffInterval=300
WaitAnswerRings=4
MaxWaitBetweenRings=10000
MinLoopCurrentOff=300
RingbackTimeout=10000
IncomingCallRings=1
MinimumMWIRequestInterval=750
TrimDisconnectTonesOnRecordings=0
OutgoingPostDialDelayMs=0
OutgoingPreDialDelayMs=0
OutdialAccess=
HookFlashDuration=0
HangUpTone=
[MWI Default]
Active=Yes
MWIType=Serial
SerialConfiguration=SMDI
UpdateDisplay=No
CodesChangeable=No
RetryCount=1
RetryInterval=5
PortMemory=No
LampOn=198
LampOff=197
[Integration]
SMDIPrefix1=
[Switch Dial Tone]
Frequency1=338
FrequencyDeviation1=40
Frequency2=451
FrequencyDeviation2=40
TimeOn1=4000
TimeOnDeviation1=0
TimeOff1=0
TimeOffDeviation1=0
TimeOn2=0
TimeOnDeviation2=0
TimeOff2=0
TimeOffDeviation2=0
Cycles=0
LearnSamples=5
LearnDelay=1500
[Switch Busy Tone]
Frequency1=479
Frequency2=620
TimeOn1=490
TimeOnDeviation1=40
TimeOff1=480
TimeOffDeviation1=40
TimeOn2=0
TimeOnDeviation2=0
TimeOff2=0
TimeOffDeviation2=0
Cycles=0
LearnSamples=5
LearnDelay=1500
[Switch Ringback Tone]
Frequency1=427
FrequencyDeviation1=61
Frequency2=502
FrequencyDeviation2=49
TimeOn1=1160
TimeOnDeviation1=140
TimeOff1=4090
TimeOffDeviation1=410
TimeOn2=0
TimeOnDeviation2=0
TimeOff2=0
TimeOffDeviation2=0
Cycles=0
LearnSamples=5
LearnDelay=1500
Frequency1=332
Frequency2=451
TimeOn1=4000
TimeOnDeviation1=0
TimeOff1=0
TimeOffDeviation1=0
TimeOn2=0
TimeOnDeviation2=0
TimeOff2=0
TimeOffDeviation2=0
Cycles=0
LearnSamples=5
LearnDelay=1500
Frequency1=323
Frequency2=451
TimeOn1=4000
TimeOnDeviation1=0
TimeOff1=0
TimeOffDeviation1=0
TimeOn2=0
TimeOnDeviation2=0
TimeOff2=0
TimeOffDeviation2=0
Cycles=0
LearnSamples=5
LearnDelay=1500
105
