4FXO ports as backup for T1/PRI during SRST
4FXO ports are used as backup for T1/PRI during SRST, in which there are a few different pots dial-peers to T1/PRI. My question is if there is some easy way to configure the pots dial-peer for 4 FXO as lower preference than PRI. Otherwise, I have to write many same dial-peers with different FXO ports.
Can I configure the 4FXO as a trunk,and create one pots dial-peer for each destination-pattern to the 4FXO ports as backup? Is there any example?
JJ
1 REPLY
Re: 4FXO ports as backup for T1/PRI during SRST
JJ,
Check this link
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f40.html#wp1622963
Try using Trunkgroups.
Sankar
PS: please remember to rate posts!
194
