Community Member
5350 for voice and data calls
Hi all,
I was wondering if its possible to configure 5350:
1- 1 E1 for both VoIP and data calls handling ?? if yes what will be the config ?? if not then
2- 1 E1 for VoIP calls and other E1 for data simultaniously ?? if possible what will be the config ?? and if this is possible then
3- What if i want to use 2 RADIUS server 1 for VoIP call AAA and other
for data calls.
What i have done so far is 5350 for VoIP calls only with 1 RADIUS. Now i was thinking to use 1 e1 for data calls and other for Voice and they both use different RADIUS. What i know if multiple radius host are configured they are used with the priority. Any idea ??
1 REPLY
Silver
Re: 5350 for voice and data calls
I understand you are trying to configure both Voice and data in a single E1 .
Please check the following URL where it has a configuration for both voice and Data
Distinguishing Modem and Voice Calls on Cisco AS5xxx Gateways
http://www.cisco.com/warp/customer/788/voip/modem_voice_gateway_9374.html
93
