6624 Blade brackout cable
I'm trying to find the part number and the name for the cable which connects 6624FXS to 110 Block.
Thanks for you help
Re: 6624 Blade brackout cable
There isn't a cisco cable to do this.
Have a look at black box for an RJ-21 cable / telco cable. i've found the most economical way is to buy the twin ended male and cut it in half and you then have two cables and just terminate the ends onto whatever you like. A patch panel is usually best if you have a structured cabling scheme.
here are the black box part no.s and $prices
Male 50-Pin Telco to Male 50-Pin Telco
5-ft. (1.5-m)
ELN27T-0005-MM
67.95
25-ft. (7.6-m)
ELN27T-0025-MM
103.95
50-ft. (15.2-m)
ELN27T-0050-MM
142.95
100-ft. (30.4-m)
ELN27T-0100-MM
217.95
Paul
Thanks for your help Paul,
Can you tell me where can I buy this cable from ?
Blue
Greybar carries them. Grey bar also carries a breakout box that has rj11 ports on it. You connect it to the vg248 and then you do not need a 110 block. Personal preference more than anything. The part number is:
ALLEN-TEL - AT125-SM - Bridging Adapter
Greybar carries this as well.
115
