7835 for 7825 replacement
Is a 7835 replacement for a 7825 supported??
Install new server with same computername & IP settings. Install Callmanager until exactly the same version (3.3(2c)) and do a restore server with the MCS.sti from the 7825???
I guess it wouldn't be a problem, but has anybody don this? and did he find any problems????
Please advice, I must do this tomorrow......
kind regards
Sascha
1 REPLY
Silver
Re: 7835 for 7825 replacement
This can be done successfully , and the below links give a detailed procedure on how to do it.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guide09186a00801800d2.html
111
