7905G firmware load with ITS
Hi there,
I have a 7905G with LD0100SCCP021114C.zup firmware. The 7905G file that comes with ITS is CP79050101SCCP030530B.sbin but when the phone requests a download it asks for CP79050101SCCP030530B.zup. What options do I have to overcome this issue ?
Phil
Silver
Re: 7905G firmware load with ITS
You may need to change the file extension to .zup, otherwise here is the upgrade procedure to load the new image direct from your PC to the handset.
Download the appropriate ATA zip file and unzip it on your PC.
On your PC, click on the start/run icon, type in ‘CMD’ , click on OK to open a DOS window.
Change to the drive/directory which holds the 7905 software files
Enter the following command line:
D:\7905 software>ldus -any ld-v1-00-h323-020603b.zup
The command line uses the following parameters:
ldus –any
ldus ATA upgrade program
-any Allow upgrade even if software version is less than or equal to those of client box.
Software image to be loaded on to handset
After the LDUS utility is run, the program will respond like this:
Using Host: Lab_PC-W2K5 with IP : 192.168.1.20 as upgrade server
image found: code -- ata(0x0501,0x0400)1.0
Using dialpad of your telephone (attached to your ATA box),
press ATA button to go to main menu, and enter:
100#192*168*1*20*8000# (to upgrade code)
NOTE:
Pressing 123# will announce your code's version number.
You can later verify that you have upgraded your ATA box.
This program runs continuously; Press -c to abort.
Upgrade server ready...
To initiate the upgrade on the handset
Power cycle the handset
Press and hold the * and 0 buttons and the 4th (right hand side below display) softkey
Display will read :
Configuration
Enter Option:
The options are the same as the IVR options on the ATA186 so you can use any of the numeric commands to provide IP addresses, subnet masks etc. If there is any text after the 'Enter Option:" , use the softkey labeled ‘<<<’ to clear the text.
To upgrade the firmware:
Key in option 100#
Display will now read :
Configuration
Enter Option:100
Enter Upgrade Server IP:
Key in IP address of PC running the LDUS utility , using * to seperate octets, and then add *8000# to indicate tftp port number - for example:
192*168*1*20*8000#
Display will clear, then it will read :
Upgrade Server : 192.168.1.20
Downloading XXXXX
The XXXXX will count down as the upgrade progresses.
Phone will reboot in new version of software
Thanks, this is very useful information. If I plug the phone into Call Manager to upgrade to CP79050101SCCP030610A then plug into ITS it then upgrades ok. The problem is using the PC or Call Manager is not practical in a real world scenario with multiple phones to be connected on site. I also tried creating a lddefault.cfg file and loading on ITS router but although the Phone seems to download the .sbin image it does not upgrade.
Can I just change the file extension from .sbin to .zup without any issues ?
If so, I presume I would need both files loaded in flash.
Ideally it would be nice to be able to load the router with the default ITS files (.tar) and the phones to upgrade without any intervention.
292
