7912G issue
I have a problem with a 7912G, when a connect to the lan it does not start. It lights the two buttons but the ligts turn off an it try to start again.
Álvaro
Re: 7912G issue
From a power & connections viewpoint:
- it's getting power, or you wouldn't have blinky blinky
- assuming you have a PoE switch, you are connected to the switch. If using bricks, check for switch connectivity.
- you might check the associated patch cables anyway
Do you have the appropriate VLAN configured on the switchport for voice?
Have you swapped it with another phone to see if it loads?
Re: 7912G issue
Yes, i have conected other phone to the same cable and the it works.
128
