7914 Expansion module - all lights are solid red
superduperlopez
I am trying to get an expasion module 7914 to work with my 7960.
These are some extracts from my config:
CONFIG (Version=4.0(1))
Version 4.0(1)
Cisco CallManager Express
load 7914 S00104000100
load 7960-7940 P0030702T023
At the moment when I go into the ephone with the expansion module, I can NOT enter the "add-on 1 7914" command. It is simply not available and not listed when I do a "show a?" command under the ephone
It seems to me that I am using the correct firmware but I can't get the expansion module to do anything. It simply sits there with a blank screen and all the buttons lighted in solid red.
The 7960 attached to it is working properly.
Any ideas why this is happening?
Thank you
5 Replies 5
superduperlopez
Forgot to mention.......
maybe this helps....
the router is a 2811 with Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(4)XC
Again, Thank you for any help
chartford
I have experienced this before. Do you have this command in your CME? tftp-server flash:S00104000100.sbn
tnooning
The command is actually 'type 7960 addon 1 7914'.
Tommer Catlin
If you don not plug a power supply into the 7914, it will not work. Not sure if you have that already. the phone will work on POE, but the attached 7914 will only work with a power supply.
mlevenstein
I am responding because we also had difficulty getting our two 7914 expansion modules to work with our 7960.
I'm not sure I understand your problem with configuring the ephone. Are you using a telnet into the CME gateway and the CLI (Command Line Interface). I would do it that way, not through any kind of browser or GUI.
You will need to log in in enable mode and then
CME# config t
CME# ephone
CME# type 7960 addon 1 7914
Hope this helps some... Try TAC if all else fails.
