7940/7960 Firmware Issue SCCP
I just upgraded the firmware to 8.0(2) on CM 4.1(3) SR3a. Now I'm starting to get intermittent one-way conversations on internal calls. Basically it appears that the callers phone is muted so that the called party hears nothing when they answer the phone. Anyone see this problem?
Silver
Re: 7940/7960 Firmware Issue SCCP
when the call is connected, press ii on the phone to get the call stat> and check if the TX and RX packet is increasing on both phones? if not, which end is not getting the packet?
Hi! Have you had any updates to this?
Jeff
Jeff
I couldn't easily replicate the the issue so I had to roll back to 7.2(4). TAC wanted me to test for Rcv & Xmt failures on either side of the call. Unfortunately I couldn't allow that error to occur for very long so I had to roll-back the firmware. I see that there is now a 8.0(3) SCCP for 7940/60s.
Joe
Thanks Joe.
We are running 8.0(3) on a few phones here before we upgrade CCM and have seen a similar problem.
Did you see this error on a 7940 or 7960 (or both?) handset?
Jeff
Jeff
We had the problem on both 7940s & 7960s.
Joe
173
