7940 phones ; static issues on line
I have a customer that has 7940 phones and about 3 out of 7 users are having static issues all of a sudden.
First thing I checked was the line cord, swapped out with known working and seemed to resolve problem - get anew line cord. Customer says still happening, can't see anything on 3550 or 3640 VG that would point anywhere. CallManager is registering phones.
Any idea where to look in either VG or 3550 for potential source?
3550 = c3550-i9q3l2-mz.121-13.EA1a
3640 = c3640-is-mz.123-5.bin
Thanks.
Re: 7940 phones ; static issues on line
Check to make sure that you have VLAN's for the voice and data.
Also, easy one to check is the cabling infrastructure. I had a client that was running CAT3, and some of the IP phones were set to "Auto" when they should have been 10F.
You may want to force your phones to 100F at the switch and at the phone to see your static goes away.
Yes, we have a vlan for voice and one for data, the switch is set for 100/full on all ports.
ex of a user:
interface FastEthernet0/3
description IP Phone
switchport trunk native vlan 79
switchport mode trunk
switchport voice vlan 80
no ip address
duplex full
speed 100
spanning-tree portfast
How do you set it on the phone, looked in CCM and couldn't see any settings. I have a 7940 on my desk and couldn't see how to change it.
did --> "settings", "Network Configuration", scroll down to item40-SW Port Config" but no way to change it.
My phone display shows "AUTO" just like the user having issues bu my phone has always been OK..
Thanks for your help on this....
on the SW port config (option 39)
press * * #
This will let you "edit" the SW port config
Now just type in 100F and validate it.
Keep an eye on your MOS scores also before and after to see if this does anything. When you are on a call, you can hit the ? button twice to get stats on the current call.
I had a static issues at one of my sites. A lot of users had their handset volume turned up all the way which caused you to hear the echo canceller which could be interpretted as static. I personally was able to reproduce the issue and it seemed to create static at the end of words/sentances, etc.
I fine tuned volume levels on the voice-ports using input gain which allowed people to lower volume on their phones and the problem went away.
Also, to edit the duplex settings on the phone you were in the right place. You need to press **# so the lock icon at the top of the screen changes to unlocked. Then you can press the edit button on SW Port Configuration and type in 100F.
Good luck.
Thanks to all for your help, I will let you know what I find out. Have a good weekend.
199
