7960 Phone and VAD
We have a 7960 IP phone using the Skinny Protocol, is there away to turn on/off VAD on the phone. I've seen how you can do it if the phone is running SIP but not skinny. Thanks
  • Other Collaboration Voice and Video Subjects
fc
Re: 7960 Phone and VAD
I've seen "Enable VAD" on SIP phones also? What does it do and when should it be enabled or disabled?
F C Wood
fc@wood.org
VAD is "Voice Activity Detect" which is basicaly the same as Silence Supression. The idea behind it is to reduce RTP traffic when there is no conversation between the parties.
fc
Since the idea is to reduce RTP traffic, is disabling Voice Activity Detect (VAD) undertaken mostly to free up bandwidth?
F C Wood
fc@wood.org
when using skinny VAD is controlled from the Callmanager
Blue
To disable VAD on Cisco CallManager, ensure that the following parameters in the CallManager are set to False (F):
SilenceSuppresionSystemWide
SilenceSuppresionWithGateways
Here is a funny thing. We have a CCM installed, in the main dial-peer of our voice gateway we have VAD disable (no vad) and both parameters: SilenceSuppresionSystemWide
are set to false. Even though, the silence supresion is enable on outgoing calls only, for incoming calls everything is working fine, it only happends for outgoing calls.
Any idea?
684
